Please add location records, because this setting is very good for local search engine optimization. thanks.
Hi zidanpragata,
Thanks for your message, and welcome to deSEC!
We do support LOC records. If you are using our web interface, you can manually type LOC into the record type field, even if it is not listed explicitly as a suggestion.
Hope that helps!
