Adding OPENPGPKEY
Based on this wizard; Generate DNS OPENPGPKEY Record
I want to add OPENPGPKEY-record(s), but is does not accept my input.
I keep getting the following error;
Record content for type OPENPGPKEY malformed: Incorrect padding
What am I doing wrong?
Erwin
Hi Erwin,
It’s hard to say without the record content. Can you share it?
From the error message, it appears that the BASE64 encoded key is not padded to a length that is divisible by 4. Just append one or two = characters so that its length is a multiple of 4.
You are right! I have added an extra = at the end and it work.
Thank you very much @GenericUser.
@peter is this something which can be check during entering the value?
Or make the error message a little bit more clear?
We could add that, yes. Can you please create a feature request on GitHub?
Thanks,
