Caddy - desec plugin - error writing RRSets
Hi there!
I have setup Caddy (opnsense plugin) with mysubdom.dedyn.io.
For this the Caddy desec DNS plugin is used.
In my setup it is required that the A record of mysubdom.dedyn.io gets updated by Caddy when the public IP address of my router (opnsense) changes.
However, in the logs I see the following error:
"logger":"dynamic_dns","msg":"failed setting DNS record(s) with new IP address(es)","zone":"mysubdom.dedyn.io","error":"writing RRSets: unexpected status code 400: [{},{},{\"type\":[\"Cannot modify NS records for this domain.\"]}]"
Full log:
2025-03-03T12:23:37	Informational	caddy	"info","ts":"2025-03-03T12:23:37Z","logger":"dynamic_dns","msg":"finished updating DNS","current_ips":["95.222.112.200"]}
2025-03-03T12:23:37	Error	caddy	"error","ts":"2025-03-03T12:23:37Z","logger":"dynamic_dns","msg":"failed setting DNS record(s) with new IP address(es)","zone":"mysubdom.dedyn.io","error":"writing RRSets: unexpected status code 400: [{},{},{\"type\":[\"Cannot modify NS records for this domain.\"]}]"}
2025-03-03T12:23:36	Informational	caddy	"info","ts":"2025-03-03T12:23:36Z","logger":"dynamic_dns","msg":"updating DNS record","zone":"mysubdom.dedyn.io","type":"A","name":"@","value":"95.222.112.200","ttl":0}
2025-03-03T12:23:36	Debug	caddy	"debug","ts":"2025-03-03T12:23:36Z","logger":"dynamic_dns.ip_sources.interface","msg":"lookup","ip":["95.222.112.200"]}
2025-03-03T12:23:36	Debug	caddy	"debug","ts":"2025-03-03T12:23:36Z","logger":"dynamic_dns","msg":"looked up current IPs from DNS","lastIPs":{"mysubdom.dedyn.io":{"A":["95.222.112.201"],"AAAA":[""]}}}
2025-03-03T12:23:36	Informational	caddy	"info","ts":"2025-03-03T12:23:36Z","logger":"dynamic_dns","msg":"domain not found in DNS","domain":"mysubdom.dedyn.io","type":"AAAA"}
2025-03-03T12:23:36	Debug	caddy	"debug","ts":"2025-03-03T12:23:36Z","logger":"dynamic_dns","msg":"found DNS record","type":"A","name":"@","zone":"mysubdom.dedyn.io","value":"95.222.112.201"}
Now I wonder where the issue is located?
In Caddy, the Caddy desec plugin or libdns/desec provider?
It is clear that the NS records of mysubdom.dedyn.io must not be modified and tried to be updated.
So I wonder why this happens and if it is a bug in one of the mentioned software components.
Any idea?
Thanks!
Relevant part of the Caddyfile:
dynamic_dns {
		provider desec {
			token <mytoken>
		domains {
			mysubdom.dedyn.io @
		ip_source interface vtnet0
		check_interval 60s
		versions ipv4
Hi, author of the desec plugin here. This was a bug in libdns/desec. I had misunderstood how the provider is supposed to behave. It’s fixed in v1.0.1.
Sorry for the inconvenience
