Henry
April 28, 2020, 8:34am
#1
can someone please give me an example how to delete a RRset. I got allways the response
“The requested resource was not found on this server”
This boths entries i try to delete
“created”: “2020-04-28T08:01:58.630984Z”,
“domain”: “example.dedyn.io ”,
“subname”: “”,
“name”: “example.dedyn.io .”,
“records”: [
“1.2.3.4”
“ttl”: 60,
“type”: “A”
"created": "2020-04-28T06:22:13.679219Z",
"domain": "example.dedyn.io",
"subname": "",
"name": "example.dedyn.io.",
"records": [
"\"example_test\""
"ttl": 3600,
"type": "TXT"
Regards, Henry
peter
April 28, 2020, 8:57am
#2
Hi Henry,
RRset deletion is documented here and refers to the RRset endpoint, which you can see in use e.g. here .
What status code do you receive along with “The requested resource was not found on this server”? When you delete something, our API should return status code 204 No Content
If you observe behavior that is different from the documented one, please shoot us an email to support at desec.io with your exact command input and output (you can of course mask your token).
Henry
April 28, 2020, 9:51am
#3
i need a working example to understood how it works.
What i have tried:
curl -X POST https://desec.io/api/v1/domains/example.dedyn.io/rrsets/
–header “Authorization: Token XXXXXXXXXXXXXXXXXX”
–header “Content-Type: application/json”
–data ‘{“subname”: “_mytest”, “type”: “TXT”, “ttl”: 3600, “records”: ["“frist try”"]}’
“created”: “2020-04-28T09:16:34.572642Z”,
“name”: “_mytest.example.dedyn.io.”,
“records”: [
““frist try””
“ttl”: 3600,
“type”: “TXT”
–data ‘{“subname”: “_mytest”, “type”: “TXT”, “ttl”: 3600, “records”: []}’
{“records”:[“This field must not be empty when using POST.”]}
curl -X DELETE https://desec.io/api/v1/domains/example.dedyn.io/rrsets/_mytest/
<!doctype html>
Not Found
Not Found The requested resource was not found on this server.
peter
April 28, 2020, 10:04am
#4
After the subdomain part _mytest/
, you also need to specify the record type, i.e. the final part of the URL should be rrsets/_mytest/TXT/
. Does that solve the problem?
PS: Please use preformatted format for terminal outputs to make your posts easier to digest.
mihi
April 29, 2020, 9:49am
#5
Henry:
This example should work if you use PUT instead of POST. Also with PUT, you can send an array of RRSets so you can delete more than one RRset at once.
peter
April 29, 2020, 10:12am
#6
@mihi , you can also use PATCH
, which works like PUT
except that you can leave out the ttl
(which is meaningless anyway for a deletion operation).
Henry
April 30, 2020, 11:47am
#7
thanks for all the asnwers.
curl -X DELETE https://desec.io/api/v1/domains/example.dedyn.io/rrsets/_mytest/TXT/ --header “Authorization: Token XXXXXXXXXXXXXXXXXX”
this works for me.
One problem was that i have first created a TXT entry without a subname.
But now everthings is fine.
