I’ve been using deSEC for a while and got an email stating that some action is required. I’m not the most tech-savvy person out there, so I’m struggling lightly at this:
Your provider may require you to input this information as a block or as individual values. To obtain individual values, split the text below at the spaces to obtain the
From my own account, obv. I made the keys unrecognizable.
- key tag,
- algorithm,
- digest type
- digest (in this order).
5680 13 2 2*******9ab*********bbf82f*******7b2e39d******43d5******4a
5680 13 4 b******************867**c24********************bc7****bb***********464******108
NOTE: no uppercase characters in both of those keys. In IONOS’s example pubKey, there are, and there are special characters as well +
and /
- which is why I was not sure if the second line is in fact the pubKey.
From IONOS’s Website:
In order for us to set up the DS record for you, we need your domain name and the information listed below in the following format:
> "extensions": {
> "secDns": {
> "dsData": [{
> "keyTag": 5680,
> "alg": 13,
> "digestType": 2,
> "digest": "2*******9ab*********bbf82f*******7b2e39d******43d5******4a",
> "keyData": {
> "flags":
> "protocol":
> "alg": 13
> "pubKey":
This example lists the required information for the domain example.com
"extensions": {
"secDns": {
"dsData": [{
"keyTag": 370,
"alg": 13,
"digestType": 2,
"digest": "BE74359954660069D5C63D200C39F5603827D7DD02B5 6F120EE9F3A86764247C",
"keyData": {
"flags": 257
"protocol": 3
"alg": 7
"pubKey":"/AwEAAbinasY+k/9xD4MBBa3QvhjuOHIpe319SFbWYIRj /nbmVZfJnSw7By1cV3Tm7ZlLqNbcB86nVFMSQ3JjOFMr" }
You can usually find this information in the management interface of your DNS provider. If you do not have access to this information, please contact your DNS provider.
Thanks for assisting
