A couple of month went by… and my LetsEncrypt certificate is due.
(swapped some path and addresses with XX to overcome the 2 link restriction on this post…)
$ sudo certbot renew
Saving debug log to XXXXletsencrypt.log
Processing XXXcoders.dedyn.io.conf
Cert is due for renewal, auto-renewing…
Plugins selected: Authenticator manual, Installer None
Renewing an existing certificate for codersXdedynXio
Performing the following challenges:
dns-01 challenge for codersXdedynXio
Running manual-auth-hook command: ./hook.sh
Output from manual-auth-hook command hook.sh:
Setting challenge to XXXXXXX …
Waiting 120s for changes be published.
Mon Mar 29 09:43:10 UTC 2021
Token published. Returning to certbot.
Error output from manual-auth-hook command hook.sh:
curl: (22) The requested URL returned error: 401
Waiting for verification…
Challenge failed for domain codersXdedynXio
Cleaning up challenges
Running manual-cleanup-hook command: ./hook.sh
Output from manual-cleanup-hook command hook.sh:
Deleting challenge XXXXXXX …
Token deleted. Returning to certbot.
Error output from manual-cleanup-hook command hook.sh:
Failed to renew certificate coders.dedyn.io with error: Some challenges have failed.
All renewals failed. The following certificates could not be renewed:
XXXXcodersXdedynXioXfullchainXpem (failure)
1 renew failure(s), 0 parse failure(s)
IMPORTANT NOTES:
- The following errors were reported by the server:
Domain: coders.dedyn.io
Type: unauthorized
Detail: No TXT record found at _acme-challengeXcodersXdedynXio
To fix these errors, please make sure that your domain name was
entered correctly and the DNS A/AAAA record(s) for that domain
contain(s) the right IP address.
