Hello, i try to add cloudflare to dedyn domain but it dosen’t work or i do something wrong. I pointed my server ip to cloudflare and i added cloudflare nameservers to dedyn domain and it dosen’t work, cloudflare confirm the nameserver was added but website not work, what i do wrong?
Hi aveurs,
welcome to deSEC!
In order to help you out, we probably need more information.
- Which Cloudflare service are you using?
- What are the NS records for your dedyn domain precisely?
- What did you try to determine it is not working?
3a. What was the expected result?
3b. What was the actual result?
Best,
For example i add cloudflare protection, i point host server ip to cloudflare dns and i add cloudflare nameservers to dedyn domain:
When i try to open the website it say dns not resolvable.
Thanks!
Please contact support@desec.io to address this, thanks!
Did you get an Answer from Support? I got the same Issue. Cloudflare is configured with Name Server, Website ist accessible but Cloudflare seems not to working. When i block for Example the whole Traffic.
Please see:
