i am hosting at kinsta and to add the subdomain i have to add the follwoing a 162.159.152.19
You’ll need to describe your problem in more detail if you expect any help.
- What did you do?
- What happened? Specifically where does the not allowed message come from?
- What did you expect to happen?
- Is this on a managed domain or a
dedyn.iosubdomain? - Are you using the web interface for creating the
Arecord or the Update API or the normal API?
