At least since May 2026 I am not able anymore to update my A record as the IP address 95.89.234.* is not allowed as a record target update.
My German Vodafone Cable connection got this IP since September last year. Every 1. of a month I successfully updated my dedyn.io record so it gets not deleted automatically after a couple of month. This does not work anymore.
This IP seems to be false positive on a black list. Please fix. Thank you.
Whois info:
% This is the RIPE Database query service.
% The objects are in RPSL format.
% The RIPE Database is subject to Terms and Conditions.
% See https://docs.db.ripe.net/terms-conditions.html
% Note: this output has been filtered.
% To receive output for a database update, use the "-B" flag.
% Information related to '95.88.0.0 - 95.89.255.255'
% Abuse contact for '95.88.0.0 - 95.89.255.255' is 'abuse.de@vodafone.com'
inetnum: 95.88.0.0 - 95.89.255.255
netname: KABEL-DEUTSCHLAND-CUSTOMER-SERVICES-18
descr: Kabel Deutschland Breitband Customer 18
country: DE
admin-c: KDG40-RIPE
tech-c: KDG40-RIPE
status: ASSIGNED PA
mnt-by: MNT-KABELDEUTSCHLAND
mnt-lower: MNT-KABELDEUTSCHLAND
mnt-routes: MNT-KABELDEUTSCHLAND
created: 2009-01-05T12:45:59Z
last-modified: 2015-06-09T13:26:09Z
source: RIPE
role: Kabel Deutschland RIPE
address: Vodafone Kabel Deutschland GmbH
address: Germaniastr. 14-17
address: 12099 Berlin
address: Germany
admin-c: FM464-RIPE
admin-c: MM45323-RIPE
tech-c: MM45323-RIPE
abuse-mailbox: abuse.de@vodafone.com
nic-hdl: KDG40-RIPE
created: 2015-06-06T09:42:03Z
last-modified: 2019-10-28T12:25:04Z
source: RIPE # Filtered
% Information related to '95.89.128.0/17AS31334'
route: 95.89.128.0/17
descr: Kabeldeutschland Route
origin: AS31334
created: 2009-04-20T13:03:44Z
last-modified: 2009-04-20T13:03:44Z
source: RIPE
% Information related to '95.89.128.0/17AS3209'
origin: AS3209
descr: VFKD Route
mnt-routes: ARCOR-MNT
mnt-by: MNT-AS31334
created: 2020-06-16T10:25:54Z
last-modified: 2020-06-16T10:25:54Z
source: RIPE
% This query was served by the RIPE Database Query Service version 1.122 (DEXTER)
