Hello, my domain doesnt work. I created NS for unt.az, but in my router write “authentication failed” during 2 days. What I did wrong?
Hi @ais,
Not sure this is the issue but Port 443 (i.e. HTTPS)is closed for the domain name
And here is what is shown for DNS
@ais Looking at unt.az | DNSViz no DS records exist pointing to the DNSKEY. You need to get your domain registrar to get these records set in the parent domain (az.).
Until that is handled, your domain is not DNSSEC secured. And what is the point of using deSEC if you don’t have DNSSEC?
Apart from that, you would need to be more specific as to what “my domain doesnt work” actually means. The message from your router does not help as we don’t know what it was trying to do.
Taking a guess it might have been trying to update DDNS A and/or AAAA records? It could be that the router was referring to the authentication credentials of the deSEC DDNS Update API? If so, did it work sometime in the past or never? Since you did not specify which router you are using we can’t help with specifics there. But you will need the domain name (unt.az) and a valid token as credentials. Note that you will be shown the needed secret value of a token only once. If you missed noting it down, then you’d need to create a new token.
HI @ais,
https://www.iana.org/ information on Delegation Record for .AZ
Using https://whois.az/ here is what I find for the domain name (unt.az )
to assist in finding the Registrar (and if they even support DNSSEC).
Info for domain UNT.AZ
Name Servers: NS1.DESEC.IO,NS2.DESEC.ORG
Status: ok
Email: israfil@ibrahim.az
Voice phone: [Not published]
Fax: [Not published]
International info:
Organisation:
Address:
Country Code: [Not published]
Province: [Not published]
City: [Not published]
Street addr: [Not published]
Postal code: [Not published]
Status: ok
International info:
Organisation:
Name: Israfil Ibrahim Saday
Address:
Status: ok
International info:
Organisation:
Address:
Status: ok
International info:
Organisation:
Address:
