sorry for my bad english, i used a translator.
I have been using deSEC for 2, 3 years now and I am totally satisfied. After a hardware defect and rebuilding, I am no longer connected to dedyn.io, the name resolution does not work.
I have the data in my Fritzbox
Update URL - “https://update.dedyn.io”
Domain name - “mydomain.dedyn.io”
Username - “mydomain.dedyn.io”
Password - “Password” (from my login account)
registered, but the Fritzbox shows an error.
Is it correct that I use the password from the login or do I need my own password?
(Initial setup was so long ago and worked immediately)
you need to give authentication token to your router. To create a token, please login at desec.io/login, then click “token management” and create a new one. The value will be displayed at the bottom of the page.
