Problems updating IPv6 prefix
I am testing the new (PR #1112) mechanism to update mutilple hostnames and to use a prefix instead of a full IPv6 IP. My URL looks similar to this:
https://update.dedyn.io?hostname=<subdomain>.dedyn.io,<host2>.<subdomain>.dedyn.io,<host3>.<subdomain>.dedyn.io&myipv4=192.0.2.1&myipv6=2001:db8:1::/56
(<subdomain>, <host2>, <host3> have real values of course and they all have existing A and AAAA RRsets.)
However I am getting HTTP Status 500 and the following response instead of good:
<!doctype html>
<html lang="en">
<head>
  <title>Server Error (500)</title>
</head>
<body>
  <h1>Server Error (500)</h1><p></p>
</body>
</html>
More tests:
  • The same thing happens when using ipv6 instead of myipv6 as the parameter name. ipv6 is explicitly mentioned in the documentation to work with a prefix whereas myipv6 is not.
  • I tried 2001:db8:1::1/56 instead of 2001:db8:1::/56, i.e. including an Interface Identifier, as mentioned in the documentation. Same result.
Is this a bug or am I doing something wrong?
Thx.
Note: When I use a complete IPv6 address instead of a prefix, the same call works fine.
This is a bug, thanks for catching it. Sorry that this is happening.
Can you please report it on GitHub? We’ll then prepare a fix.
Thanks,
This has been fixed in PR #1155.
Thanks!
