I created my subdomain but I can’t access it. It’s been more than 24 hours since it was created. Domain: www.datacoren8n.dedyn.io
Did you add any DNS records?
The domain datacoren8n.dedyn.io seems to exist:
$ dig +short datacoren8n.dedyn.io ns
ns2.desec.org.
ns1.desec.io.
But there don’t seem to be any interesting records for the subdomain www:
$ dig +short www.datacoren8n.dedyn.io a
$ dig +short www.datacoren8n.dedyn.io aaaa
Or for the domain itself:
$ dig +short datacoren8n.dedyn.io a
$ dig +short datacoren8n.dedyn.io aaaa
Also please note that deSEC provides DNS services only. No webserver or email, etc. So if by access you mean that you are expecting e.g. a webserver then you need to provide that yourself.
Hi juliosaopedro,
Thanks for your message, and welcome to deSEC! ![]()
It appears that you entered the full domain in the subname field, but only the subdomain part (“www”) got there. Hope that helps!
I identified this by simply trying the following query:
$ dig +noall +answer www.datacoren8n.dedyn.io.dedyn.io
www.datacoren8n.dedyn.io.dedyn.io. 3600 IN CNAME io.dedyn.io.
io.dedyn.io. 3600 IN A 192.168.1.40
Note that the CNAME target io.dedyn.io likely is also not what you want. (You probably want to put an A or AAAA record for subname “www”, or a CNAME that points to your full domain without subdomain.)
EDIT: The query I made obviously belongs to io.dedyn.io (which is not your domain). There is a wildcard CNAME configured there, which resulted in the above answer. None of this has anything to do with your domain, so please ignore the above. Apologies for the mistake!
