I have several domains for private use registered with strato. Since a few days I’m not able to use more than 1 domain with desec, they want to have it delegated with DNSSEC. I contacted the strato support, according to them it’s not possible to use own DS records with third party nameservers. Its pssible to use DNSSEC with theri own nameservers only. Therefor I can’t put in the ds records to use it with desec, any experience with strato, any ideas, do i have to change the domain registrar?
Your registrar uses DNSSEC as an upselling opportunity. Don’t expect them to poke a hole in that strategy by allowing you to use DNSSEC with external nameservers.
netcup didn’t implement DNSSEC very well. They offer it, but their support team says you shouldn’t use it because it’s very prone to errors.
I had DNSSEC enabled on my domains and was monitoring them. One night, I received a message from my monitoring system saying that DNSSEC was malfunctioning, even though I hadn’t changed anything.
That was also the reason why I’ve since migrated all my domains from netcup to febas.de
Netcup has been working on a new DNS management system which should not have these problems anymore. New domain registrations already use the new system. Domains that still use Netcup’s legacy system are being migrated by and by. DNSSEC is officially supported and free at Netcup.
