Tokens only allowed for certain domains
I was wondering if it would be possible to have tokens for only certain domains.
For example I want a token that is only allowed to update mydomain.com but not myotherdomain.com
This would limit access tokens for DynDNS to only update the domain they need to update.
Yes, that is possible. It is also possible to limit a token to be able to write/modify only a certain subname and/or certain RRsets.
See: Token Scoping: Policies
There is no web UI for setting this up. You need to use the API.
