Tools implementing deSEC
I vaguely recall that for certbot, there’s something like you are doing for acme.sh (thanks for pushing this!), but I can’t find it just now. Will update this post if I find it.
That said, it eludes me why one should rotate the private key frequently. OTOH, exercising the process might be enough justification in itself …
https://github.com/tlsaware/danebot:
danebot is a certbot wrapper that helps to avoid SMTP outages due to mismatched TLSA records resulting from a Let’s Encrypt automated certificate renewal.
@mdbraber
Hi there!
If you are still using dehydrated - like me :innocent: - the following hook might be interesting:
dehydrated_desec
Cloudron recently added support for using domains hosted on deSEC. They are currently facing some issues regarding DNS-based Let’s Encrypt challenges timing out. Cloudron is an amazing product that I think aligns with the ethos of deSEC. Maybe someone has an idea how they could solve their issue and bring full deSEC support?
Thanks, I’ve included it in the top post.
uacme has a 3rd party hook for doing DNS-01 challenge; GitHub - ndilieto/uacme: ACMEv2 client written in plain C with minimal dependencies
Hi quite,
We’ve added your suggestion to the list at the top.
Created this quick and dirty script. May save time for someone.
Noob friendy, will guide you.
Intended to be used with
DynDNS shell script for deSEC:
@FilleMang @KapernMagIchNicht We’ve included your suggestions in the top post!
Hi there, I’ve been using deSEC for a year and decided to write a webhook provider for ExternalDNS.
Still under development, but contributions are welcome :slight_smile:
Ferron
Ferron v2 ( GitHub - ferronweb/ferron: A fast, memory-safe web server written in Rust. ) supports also deSEC.
    auto_tls
    auto_tls_contact "E-MAIL"
    auto_tls_cache "letsencrypt-cache"
    auto_tls_letsencrypt_production
    auto_tls_challenge "dns-01" provider="desec" api_token="TOKEN"
Stalwart
Stalwart dns-update (GitHub - stalwartlabs/dns-update: Dynamic DNS update library for Rust) and therfore Stalwart ( GitHub - stalwartlabs/stalwart: All-in-one Mail & Collaboration server. Secure, scalable and fluent in every protocol (IMAP, JMAP, SMTP, CalDAV, CardDAV, WebDAV). ). But there is sometimes an progagation timeout. Disscussion at https://github.com/stalwartlabs/stalwart/discussions/2098
Tip for Caddy
https://*.DOMAIN:8443 {
        log
        log_skip /health
        log_skip /metrics
        tls {
                dns desec {
                        token "TOKEN"
                propagation_delay 2m
        respond /health 200 {
                close
        encode {
                br 8 15
                gzip 5
                zstd
        root "/wwwroot/"
        file_server {
                precompressed br gzip
Hi @al-desecnone.at,
Welcome to deSEC, and thanks for your message!
What would be a good link to include in the top post of this thread (such as: documentation how to use deSEC with Ferron)?
I would say this Link is the best one Automatic TLS - Ferron
Done!
I just stumbled on your fantastic project so I’ll start with greatly deserved congrats for the work and thanks for sharing it and making it available for free! :clap: :folded_hands:
Then I found that it was also supported by OctoDNS thanks to the octodns-desec module and thought it would be a nice addition to this list :slight_smile:
Thanks again and HNY to yall DNS freaks ;-*
Hi silopolis,
Thanks for the kind words, and welcome to deSEC! :slight_smile:
We’ve added your suggested to the list at the top.
I’ve implemented a new TF provider based on the “new-ish” provider framework. The provider is here: Terraform Registry . Some highlights are:
  • Ephemeral resource for tokens
  • List resources that allow to easily import and generate configs for existing setups and audit. See Bulk Import and Config Generation and Auditing Guide
  • Provider functions for things like punycode domains and OpenPGP DANE
  • Complete set of resources and data sources mapping the desec.io REST API
  • Logic to properly respect rate limits
  • Resource to use bulk API for RRSets. This includes managing an exclusive list of RRSets for a domain and managing those via DIND zone file.
We also have a simple getting started guide: Getting started guide.
Disclaimer: the provider is rather new and feedback is welcome per GitHub issues on the provider project.
Thanks, @timofurrer, I’ve added this to the list at the top!
Maybe it would have been better off here: Ansible desec role - #2 by Tealk
