Tools implementing deSEC
In this post, we keep a list of deSEC-aware software that we have knowledge of.
Note: This does not imply any endorsement by deSEC. We also do not evaluate whether the tools listed here implement sensible security measures, nor do we know whether these programs hold what they promise. The list is merely meant as an inspiration for digging deeper into the deSEC ecosystem.
dynDNS clients
Integrations
DNS orchestration
ACME clients
Webserver in-built
Other
  • Proxmox Virtual Environment, e.g. pvenode
  • Traefik supports deSEC through lego (see ablove). Previously, there was this extra module: Traefik dedyn-dns01 (now superseded)
General purpose API clients
Libraries
Command-line Interface (CLI)
To extend this list, please reply to this post, and after short inspection we may include your suggestion in the list.
dnscontrol will also get support for desec: https://github.com/StackExchange/dnscontrol/issues/724
Hi d3luxee,
Support was just merged into DNSControl, so I added it to the above list. Thanks for the contribution!
Lego (an ACME client) has deSEC support too now! I filed the issue asking them to implement it, and the next day it was done: https://github.com/go-acme/lego/issues/1140
I created a Go client: https://github.com/nrdcg/desec/
You can also remove Traefik dedyn-dns01 as Traefik support deSEC natively (through lego)
https://docs.traefik.io/v2.2/https/acme/#providers
Hi vika, ldez,
Thanks for your contributions! This is really great to see <3 I’m making the corresponding changes to the list.
Thx for adding my stuff. :smiley:
I’m currently finishing up the python API wrapper. I’ll release the first 1.0 beta in a couple of days.
After that I’ll continue working on the ansible modules. So feel free to test the desec-dns-api library and give feedback.
I just uploaded my PHP library to connect to deSEC API.
Hi Taras,
Thanks for your contribution! I’ve added it to the top post of this thread.
Hi! I found a Caddy module that supports DNS ACME challenge using a deSEC API token: GitHub - caddy-dns/desec: deSEC module for Caddy
Hi strawberry,
Thanks, I added it to the list!
desec-dns-api does not exist anymore on pypi. A relatively new project appeared at desec.
Thanks, RonObvious, I made these changes!
The repository is marked as archived and the project is in readonly mode. Looks like PyPI releases have all been yanked too. This should be marked as unmaintained or abandoned.
Hi WhyNotHugo,
I verified your report, and removed the unmaintained link from the collection.
Hi everyone,
I’m excited to share with you a small script I’ve developed to simplify the process of updating TLSA records from Plesk. You can find the script on GitHub at this link: Plesk-DANE-TLSA-and-deSEC
TLSA records are an essential part of ensuring secure communication over the internet, particularly for services like email and web servers. However, managing these records manually can be cumbersome, especially for those using Plesk as their hosting control panel.
With this script, I aimed to streamline the process, allowing Plesk users to update their TLSA records seamlessly. By integrating with deSEC DNS service, the script automates the update process, saving time and effort for administrators.
I encourage you to check out the script on GitHub, where you can find detailed instructions on how to use it and contribute to its development. Whether you’re a Plesk user looking to enhance your server’s security or a developer interested in improving the script, your feedback and contributions are highly appreciated.
Thank you for your support, and I hope you find the script useful!
Best regards,
Jonathan
I wrote a tiny program in go that reads a zone file and writes all of its records using the API: ~whynothugo/zone2desec - Write a zone file to desec.io - sourcehut git
I like to keep my domain definitions in zone files (which are pretty standard). This lets my use the zone file as source of truth and writes to deSEC any changes.
Currently it won’t delete records that are removed from the zone file. I might add a --prune flag to do this in future.
Are there any tools who fully implement a TLSA rollover by using a current+next private key? Most implementation seem to ‘just’ publish a single TLSA record without providing a current-next rollover as suggested (see https://imrryr.org/~viktor/ICANN61-viktor.pdf, slides 20+21). A single TLSA record would mean possible downtime when renewing certificates.
I’ve found this, in combination with acme.sh and the --force-new-domain-key option:
GitHub - nixigaj/cf-tlsa-acmesh: A simple Go program that lets you automate the updating of TLSA DNS records with the Cloudflare v4 API from acme.sh generated keys, including a rollover (next) key.. I’ve recently rewritten this to be more generally used with any libdns provider, which includes desec. I’ll upload that after I get back from my holiday.
Also it would be great to have Caddy implement current-next key rollover; I’ve submitted an issue to create a PR here: Allow Certmagic to generate 'next' private key to allow safe TLSA/DANE deployment and rollover · Issue #294 · caddyserver/certmagic · GitHub which shouldn’t be too hard to implement.
If there are any other good TLSA rollover options (besides acme.sh) I’d love to hear!
Not exactly what you are looking for and somewhat more complex, but there is this:
This provides certificate renewal and TLSA key rollover as an application for MicroVMs. It shouldn’t be too hard to port this to a more traditional environment if you don’t like MicroVMs.
