UDM Pro Configuration
Hello
I switched from a FritzBox 7590 to a Unifi Dream Machine Pro and I have the problem that I can not find a configuration to update my IP address. The program that uses the UDM Pro is “inadyn”. Has anyone here, perhaps, got a UDM Pro to update the IP address?
With kind regards
and many thanks
just if someone has the same question.
At my UDM Pro with Network App Version 7.1.66 it works with the following settings.
Service: dyndns
Hostname: <fqdn to be changed>
Username: <fqdn to be changed>
Password: <token>
Server: update.dedyn.io/?myipv4=%i
Regards,
Thomas
Hey tkriener,
welcome to deSEC! Thanks for the hint, it is much appreciated :slight_smile:
Best,
Anyone tried this in unifi recently? Can’t get it to work.
Still working on my UDM with OS 3.2.9 and Network 8.0.28.
Well good to hear. Must be related to stupid inadyn caching or something. I’ll troubleshoot when I’m on site and can SSH. Thanks.
Well in case anyone else wants to force their UDM to do a dyndns update, this command works well if you SSH in…
inadyn -n -1 --force -f /run/ddns-eth8-inadyn.conf
I can confirm the settings above still work. I have IPV6 disabled.
I SSH’d and ran:
/usr/sbin/inadyn -n -s -C -f /run/ddns-eth8-inadyn.conf -1 -l debug --foreground --force
And I was able to see in my deSEC tokens that it was used, and A record in place.
