Is it possible to update a specific record, rather than the @ (root) record using the dyn DNS API? It seems that since the hostname parameter is used as the username and the name of the zone to be updated, it’s not possible to specify the actual hostname.
For example, given zone rouben.dedyn.io, if I have several A records:
foo.rouben.dedyn.io
bar.rouben.dedyn.io
I can only use the dynamic IP update API to update
rouben.dedyn.io
(i.e. the root of the zone) and not any of the above records.
Given that the account is limited to only 4 domans/zones, it’s not practical to have to create a separate zone for each dynamic IP hostname… furthermore, that approach just seems wasteful: creating a whole zone just to have a single record…
