Using a custom domain (3rd party DynDNS service) that auto-updates and redirects to my router IP.
Q: Where in my deSEC account’s GUI do I enter this domain (DynDNS) instead of a fixed IP (A record)? What type of record should I use to enter it: CNAME or NS?
An A record would point your domain to a IP(v4), AAAA does the same but for IPv6. If you want to point the domain to another domain, or a subdomain, then you can use a CNAME record.
Thank you, but also why no ALIAS records exist within deSec?
Using CNAME means I can no longer add MX records for my e-mail or CAA records for certificates, right? Is there a workaround for this?
I recommend reading the link posted earlier by @l33tlamer. It’s all documented, and it’s more respectful if you spend some time instead of asking others to spend time.
