DKIM Key explodes page layout
Hello there,
i have done some imports of BIND zone files. Basically works as it should.
One entry in the zone file had a TXT record which contains a DKIM value. This means that the Subdomain column only shows the first letter of the DNS entry.
Is it possible to shorten the line in the Content column or make a line break?
Cheers,
Daniel
Hi Daniel,
We can try to improve this, but are keeping track of bugs on GitHub. Can you please file an issue here? Issues · desec-io/desec-stack · GitHub Thanks!
