Dnssec on .es domain
Hello, quite new to domain management. I own a .es domain from GoDaddy, and manage to delegate to desec.
But I did not understand what I need to do in order to activate DNSSEC.
Consider that:
I can’t find anything similar in desec, and instructions given there seem to suggest there is something to be done by registrars’ side.
Anyway, DNSSEC for .es domain seems operational (https://www.internetsociety.org/wp-content/uploads/2021/06/2021-06-14-2021-06-14.png amongs other sources).
Thanks for help!
I had the same, rather annoying discussion. For me it was a .solutions domain. They seamed to not have a GUI workflow for that.
And they always said “you have the DNS elsewhere not set to us. We can’t do anything about that”.
So I had to really insist that THEY need to give me a DS record, no matter what DNS server my domain is pointing at.
Good luck. They suck. I moved registrar away from godaddy for my newer domains because of it.
Thanks, I imagined it was GoDaddy’s fault.
I also would like to move to another registrar, eu based if possible. I just wonder .. how can I be sure they manage dnssec for .es domain?
pretty much everybody does. At least any half respectable registrar.
I personally like hostpoint.ch, but they are Swiss based. They offer good support, but not in Spanish :slight_smile: Pretty sure you find someone like that in Spain. If in quesiton, call them up and ask. That would also double as a good first test to see if they know what they are doing.
I heard good things about INWX. Should be a german (Berlin) based company.
I can add that netcup does not support DNSSEC (and therefore also no delegation) for .es domains as well. So you are stuck with the DNS functionality of your registrar in this case.
I would strongly recommend against managing any domains at netcup, regardless of the TLD. DNSSEC tends to break very frequently there; in my case, it took eight emails of back-and-forth just to get them to add the DNSKEY manually for a .de domain.
I’ve since moved everything over to Porkbun and haven’t had a single issue since. I’d definitely suggest sticking to a larger, more established registrar that knows what they are doing.
Totally aggree with you but their domain prices are just too cheap to consider a switch to another registrar. I also had issues but not that often yet that I would call it problematic.
I understand you, but .de in my case costs almost the same at Porkbun :slight_smile:
$2.90 on sale, $5.49 regular registration, $4.07, renewal, $5.10 transfer vs 5 EUR at netcup for a .de for example. Porkbun has really good prices for domains in my opinion. You can also look them up here: porkbun.com | Domain Name Pricing
As i said, i can recommend Porkbun or INWX.
Yeah, the regular price might be the same – the discount prices are not. I pay 0.13€ / month for my .de domains. Thats incredible cheap and I’ve seen this price nowhere else. And I own way over 50 domains in the meantime so the price makes a difference :zany_face:
