Excessive limitations on permitted characters in names and subnames
I’m trying to create DNS records for DNS-SD (RFC 6763), but at least when I’m trying to do it at desec.io on the web, it’s overly stringent and prohibits me from making subnames with uppercase characters, for example. See Section 4.1.1. and especially Appendix E of that RFC for details, but in general almost all UTF-8 characters are permitted. These names used for service enumeration are not host names, and are not bound by the limitations of host names, but deSEC.io seems to be treating this as such.
For those not familiar with DNS-SD, an example will probably help. Fortunately there is an example domain, aptly named ‘dns-sd.org’. To discover all of the different kinds of services that may be associated with dns-sd.org, we perform a PTR query for the magic name used for this purpose, such as with dig:
$ dig -t PTR -q _services._dns-sd._udp.dns-sd.org  +noall +answer
_services._dns-sd._udp.dns-sd.org. 60 IN PTR	_ftp._tcp.dns-sd.org.
_services._dns-sd._udp.dns-sd.org. 60 IN PTR	_ipp._tcp.dns-sd.org.
_services._dns-sd._udp.dns-sd.org. 60 IN PTR	_ssh._tcp.dns-sd.org.
_services._dns-sd._udp.dns-sd.org. 60 IN PTR	_http._tcp.dns-sd.org.
_services._dns-sd._udp.dns-sd.org. 60 IN PTR	_printer._tcp.dns-sd.org.
_services._dns-sd._udp.dns-sd.org. 60 IN PTR	_afpovertcp._tcp.dns-sd.org.
_services._dns-sd._udp.dns-sd.org. 60 IN PTR	_pdl-datastream._tcp.dns-sd.org.
_services._dns-sd._udp.dns-sd.org. 60 IN PTR	_nq._tcp.dns-sd.org.
Now I can see that the domain has IPP services for printing. Next I can do another PTR query specifically for IPP service instances to see, in human-friendly form, what kinds of printers might be available.
$ dig -t PTR -q _ipp._tcp.dns-sd.org  +noall +answer
_ipp._tcp.dns-sd.org.	21	IN	PTR	Stuart\226\128\153s\032Remote\032AirPrint\032Printer._ipp._tcp.dns-sd.org.
_ipp._tcp.dns-sd.org.	21	IN	PTR	Sales._ipp._tcp.dns-sd.org.
_ipp._tcp.dns-sd.org.	21	IN	PTR	Engineering._ipp._tcp.dns-sd.org.
_ipp._tcp.dns-sd.org.	21	IN	PTR	3rd\.\032Floor\032Copy\032Room._ipp._tcp.dns-sd.org.
_ipp._tcp.dns-sd.org.	21	IN	PTR	Marketing._ipp._tcp.dns-sd.org.
The last column is what you should find interesting here: all of those human-readable names contain uppercase characters, and the applicable standards actually allow this. Choosing service instance names with correct case and punctuation is strongly advised.
It seems like this has been overlooked. When I try to create such a PTR subname, I’m unable to set it to something like “Engineering”, because it says Allowed characters: a-z, 0-9, and -_. May start with “." or just be "”.
When creating that record, it also asks for the “target hostname” that the PTR record should point at. Again, there is no actual, technical obligation that the target be a hostname, and the targets of the _services._dns-sd._udp.dns-sd.org PTR records most certainly are not.
In fact, DNS has a lot in common with a generic directory service like LDAP when one comes to think of it: except for particular record types where it wouldn’t make sense, the protocol is designed to be agnostic with respect to its application, and can legitimately be used to store information about things that aren’t machines at all.
I am not sure if using deSEC’s API would allow one to work around this. It seems that deSEC’s limitations on such names are artificial and self-imposed, and probably by mistake, so I would appreciate seeing them lifted so I can use meaningful names in DNS-SD.
Hi 000,
Sorry for the slow response as we’ve been working to address this!
We do not preserve uppercase/lowercase on the subname field. The reason is that many resolvers perform case randomization, so it is not preserved at query time anyway. Note also that query names are compared case-insensitively, that is, uppercase and lowercase variants are considered equal.
We’ve just lifted the restrictions on PTR record data in production, and also allowed \ to be entered in the GUI so that you can use \ddd format. Uppercase/lowercase on record data is now preserved. :tada:
Note, however, that unfortunately it is still not possible to use arbitrary bytes in PTR record data. Our API no longer imposes restrictions, but it talks to the PowerDNS nameserver under the hood via its internal REST API, and that API currently does not accept arbitrary bytes. We’ve filed a report with them and hope that the restriction will be lifted in the future. In the meantime, you may experience an error when provisioning certain characters.
Apologies for that – unfortunately, we can’t do better right now.
