Arno1
1
Using Godaddy as a registrar? Find a guide on setting up your nameservers below.
Source
- Go to your domain portfolio
- Select the domains you want to edit, then from the action menu choose Nameservers
- Choose I’ll use my own nameservers
- Set the nameservers as per the deSEC portal
Arno1
2
Setting up DNSSEC means getting the DS keys from the deSEC portal.
Follow this link for the official godaddy guide on adding DS records.
Note some domains do not support DS keys at the registry level. This means they do not allow for setting DNSSEC.
