How to configure DS records at Netcup
Hi everyone, I need your help again, as I wasn’t able to complete DNSSEC.
As advised in this forum, I send my public DNSKEY and DSKEY to Netcup and asked them, to set those values for the affected domain. They refered to their backend, where users can set those values up themselves.
However, I’m not sure what parameters to select. Do you have any ideas? Thanks!
Yeah, this is needlessly complicated. We should improve our instructions. The problem is that the registrar-side interfaces vary wildly.
If you look at your DNSKEY record, it is something like
257 3 13 <long-string>
The first number is the flags value, the second is irrelevant (it is always 3 and usually registrars don’t ask for it), and the third nmber is the algorithm value. The rest of the record is the public key, for which your interface has a separate field at the top.
Hope that helps!
I understood it now the following way:
… as the public key public? normally no need to obfuscate it, right? @peter :face_in_clouds:
Hi bsz,
I’m not sure what your question is, but yes, the public key is public, so you don’t need to obfuscate it.
thanks for the warm welcome :wink:
… just because I answered @neoda 's questions with concrete details.
I can also confirm that my posted settings are now working correctly for netcup.
I’m now curious, if these information are changing rarely, but are handled differently by registrar, if it make sense to gather these default configuration per dns registrar a thread or table?
Aha, great! Now I understand; I thought you had a question yourself.
That would make a lot of sense! I’m wondering what the best format would be; a forum thread would likely become very long if it included screenshots. Any suggestions?
