Hi, I’ve noticed that using dig utility with ANY query I do not receive empty (or minimal) response as I should. In BIND9 it can be easily achieved by specifying minimal-any yes; parameter. Can you implement same thing?
Thank you!
Hi olf0x,
Thanks for your message, and welcome to deSEC! ![]()
The issue you described is tracked here: Don't serve full ANY responses · Issue #36 · desec-io/desec-ns · GitHub
Feel free to add any comments.
Thanks Peter, I will check ![]()
