SMIMEA record creation fails in web UI for RFC 8162 compliant hashed local-part
I’m trying to add an SMIMEA record following RFC 8162 for email address patrick@domain.tld.
Working (non-standard):
  • Subname: _smimecert.patrick
  • Result: _smimecert.patrick.domain.tld
Not working (RFC 8162 standard):
  • Subname: 8d969eef6ecad3c29a3a629280e686cf0c3f5d5a86aff3ca12020c923adc6c92._smimecert
  • Result: 8d969eef6ecad3c29a3a629280e686cf0c3f5d5a86aff3ca12020c923adc6c92._smimecert.domain.tld
The hashed local-part (56 hex chars) appears to exceed the web UI’s subname length limit. The RFC requires SHA-256 truncated to 28 bytes (56 hex characters) as the first label, with _smimecert as the second label.
Question: Is this a UI validation limit? Can the record be created via API, or does the platform enforce a shorter maximum label length?
I may be misunderstanding the RFC or the correct record structure—any guidance on the proper way to create SMIMEA records with deSEC would be appreciated.
Thanks,
Patrick
Hi georgelucas0815,
The issue you observed is a bug in the validation logic used in the web interface. It would be great if you could file a bug on GitHub.
Thanks!
Hi Peter,
I forgot to cut the hash after 56 characters :face_in_clouds: everything is working as espected!
Haha and I also didn’t count correctly and then thought it was a bug, while actually things are working as intended. Thanks for the heads-up!
