I recently wanted to to switch to wildcard letsencrypt certificates for my traefik setup (due to trying aggressive geoblocking as I have lots of irrelevant connects from dubious countries, but this also blocks the letsencrypt servers and they do not publish ip addresses to add to a whitelist).
However, it does not really work and gives an error message: unable to generate a certificate for the domains [domain.org]: error: one or more domains had a problem:\n[*.domain.org] [*.domain.org] acme: error presenting token: desec: no subdomain because the domain and the zone are identical:
Any idea what that means and how I could rectify it?
can you share the config?
from the error it seems that maybe you put an extra *. somewhere it doesn’t belong, but i can’t be sure without having a look at the config
Hi, I’m currently struggling with the same wildcard problem. Reto’s solution sadly does not work for me: *.sub.example.dev. CNAME sub.example.com. with sub.example.com CNAME example.com gives the identical zone error while setting both entries to A and AAAA records with the server’s respective IP gives propagation: time limit exceeded: last error: [zone=example.com.] could not determine authoritative nameserver
As for my config, the labels on the service are as follows:
